dr dougie
- Feb 11, 2008
I like EAC for all but AAC ripping. I don't have an iPod but use iTunes for AAC which I prefer to mp3. Something free from Apple - it's a miracle!
Originally Posted by krmathis /img/forum/go_quote.gif I highly recommend Max. With the obvious choice of LAME and CBR 320kbps (since you want MP3 files). |
Originally Posted by Elluzion /img/forum/go_quote.gif Ok your right^ good point. EAC is too complicated with all of its settings and what not. WHat is an easier program to use to rip FLAC files? |
Originally Posted by Aaron5604 /img/forum/go_quote.gif I would say pay the extra bit of cash so you can access the .flac through DBpoweramp. This way you can handle all the essentials within ONE program, in as well as save yourself a few extra steps. Or, you can go grab the free version of Mediamonkey in addition to DB. Rip the .wav's from DB, and instead of messing w/ all the folder tags once more through Mediamonkey, (should this all be in bulk) just copy your original folders (subfolders and actual music files included) and temporarly store them elsewhere as duplicates. Then, through media monkey access those copied files and just change the setting to replace rather than mess w/ a whole new destination via options when making the converstion over to .flac. This way, ALL of your addtional side information (tags) will transcode over w/ no interference. Plus, you don't have to worry about re-working any of the sub folders or the file names themselves. As for your album art, just copy the originals and add them w/ the second set of files. Personally, I don't have any real use for .flac. There's only a hand full of DAP's in which support it right now. .wav (PCM) is the ONLY thing I use because it's the most supported lossless format, even though it's roughly twice the size. For me, there's just absolutely no good reason to switch back and forth between two codecs - true only pointless.. |
Originally Posted by Elluzion /img/forum/go_quote.gif I downloaded Dbpoweramp and it will let me rip .FLAC files, but then i can't use them in Itunes on my ipod. Do i have to convert the .FLAC file to .mp3 or something? is it worth all this hastle or should I just use Apple Lossles? |
Originally Posted by Aaron5604 /img/forum/go_quote.gif You need an additional program to run .flac I believe on an Ipod, such as Rockbox. |
Originally Posted by Elluzion /img/forum/go_quote.gif i realize that. but I just want to use Apples ipod software. I don't like Rockbox personally. The only lossless I can use with Apple is apple lossless. Is apple lossless ok to use in the long run to backup CD files? |
Originally Posted by Aaron5604 /img/forum/go_quote.gif Yeah, I don't care to use additional programs either... In response to your question... I can't speak out of experience w/ .alac. Text book however, it's no different in quality, for they're both respectfully lossless. DRM can be applied if someone chooses, and it shares the same end extention as the .aac codec. However, sq wise I think you're fine. |
