PhonoPhi
Hello, friend
1.) Yes, it is reversible. The white filter has a ring of sticky black adhesive around its circumference. This adhesive is reusable. When you remove the filter, it is critical to store it on something that will protect the adhesive from dust and dirt. A small scrap of waxed baking paper (commonly called “wax paper”), a wax-coated paper drinking cup (must be wax coated), a clean unused wax candle (like a small tea candle), or the backing paper from a sticker (ie the part left behind when you peel a sticker from its backing paper).
To put the mod back to its original state, you simply reverse the procedure you performed when you removed the filter (it can be set back in place with sharp tweezers, and the adhesive smoothed back down using a cotton swab or wooden toothpick). You must make sure to put the filter over the correct hole though. There are 3 holes, and it’s easy to get confused which hole is which. You can use the photo I posted as a reference so you know the correct hole to stick the filter back onto.
2.) I’m not sure, I don’t have any of those models. It wouldn’t surprise me if they did though.
3.) The metal nozzle mesh can be found on Aliexpress if you search for “dust network steel mesh”. There are many diameters available. The correct size for the C16 is 4.3mm (sometimes sold as 4.2mm). There are a few styles available - the common flexible woven mesh type we see, and the ‘cheese grater’ style with round holes in a stiff plate:
I hope that helps!
That is amazingly helpful!
Thanks a lot!!
