voicemaster
CKX is good, but at the same price $79.99 on amazon US, get the moondrop Aria instead imho.
CKX is really tempting. But at that price point, KZ/CCA is going to face "bigger" boys, the mainstay in Chi-fi's Mid-fi. From Ibasso, TinHifi, Moondrop and etc.CKX is good, but at the same price $79.99 on amazon US, get the moondrop Aria instead imho.
The CKX is a surprisingly capable set of near entry-level IEMs, though I did have to EQ it to tame some treble harshness. I got them because they were the smallest 2-pin IEM I could reasonably afford at the time. As far as that justification goes, it's still very small and comfortable and it's possible to forget you have them in if you're distracted when your album stops or your youtube video fails to autoplay to next.CKX is good, but at the same price $79.99 on amazon US, get the moondrop Aria instead imho.
Put extra $50 and get AST insteadCKX is good, but at the same price $79.99 on amazon US, get the moondrop Aria instead imho.
The DQ6 does everything better, I think it might be the best value iem. Its a bit V shaped and alot more detail/clarity with cleaner bass. CSN is relaxed, neutralish, doesn't come close to the detail/clarity in the DQ6, it has more bass but its a bit muddy.CSN or DQ6 at near same cost, which one would make more sense in terms of musicality? These will be mostly used via BT module while working out. Appreciate your help, thanks in advance.
Those treble spikes give more clarity and details in DQ6 but that's not an issue for me. It would be helpful if you can also help with size and fit differences between the two.The DQ6 does everything better, I think it might be the best value iem. Its a bit V shaped and alot more detail/clarity with cleaner bass. CSN is relaxed, neutralish, doesn't come close to the detail/clarity in the DQ6, it has more bass but its a bit muddy.
If you like BAs and ZSN - CSN may work, more mighty bass than ZSN.CSN or DQ6 at near same cost, which one would make more sense in terms of musicality? These will be mostly used via BT module while working out. Appreciate your help, thanks in advance.
I've only tried the KZ ZS5 and CCA CKX. The CKX may be expensive compared to most of these, but it does sound surprisingly nice and detailed. It's got pretty close resolution compared to the TRI Starsea, it mainly just loses out in terms of timbre in the mids and highs, but not by as much as I had expected. The bass is more impactful on the CKX, but lacks some of the texture that the Starsea offers.If you like BAs and ZSN - CSN may work, more mighty bass than ZSN.
I feel some BA-DD disconnect with CSN due to its dominating bass, but not to any point being not enjoyable.
DQ6 are also great, some complain of trebly peaks, 3DDs sound a bit more unique.
Both are nice choices.
I can also add that somehow CA4 resonate most with me in this category due to its a bit more gentle W.
What is the price difference between CSN and CKX, three times at least, right?I've only tried the KZ ZS5 and CCA CKX. The CKX may be expensive compared to most of these, but it does sound surprisingly nice and detailed. It's got pretty close resolution compared to the TRI Starsea, it mainly just loses out in terms of timbre in the mids and highs, but not by as much as I had expected. The bass is more impactful on the CKX, but lacks some of the texture that the Starsea offers.
I like the DQ6 better. The CSN is good too, but it is larger so fit can be an issue for some people. My CSN has this echo going on inside the shell that I can hear very clearly when there is nothing playing when I clenching my teeth which is weird and interesting at the same time.CSN or DQ6 at near same cost, which one would make more sense in terms of musicality? These will be mostly used via BT module while working out. Appreciate your help, thanks in advance.
ZAX is a hybrid. CKX and ZAX is like 98% similar in sound imho. The build quality is a lot superior in the CKX (all metal vs resin), the CKX is also tiny like is how they fit all these drivers inside such a tiny shell.What is the price difference between CSN and CKX, three times at least, right?
I have ZAX, it is great (minus its BA bass) I do prefer all BAs for their resolution, the discussed "timbre problems" do not bother me.
So I am not planning to get CKX. I used to be a CAA fan, collecting "all their Pokemons", not anymore, they lost me.
C16 and CA4 are still the nicest of CCA offerings to me.
My recent debacle wirh TRI I3 and few others taught me that it is better to enjoy what you have and the music rather than trying to chase those unattainable unicorns wasting time, money and energy...
