alamnp
I'm frustrated that Crinacle doesn't have the CCA CA16 graphed so I can compare to my C12... there is a Crinacle graph of C12 vs. ZAX, showing they're pretty much identical up to 4.5k-5.5k where the ZAX is more relaxed there (and closer to Harman by about 4db). Fortunately I did find a youtube review by Bad Guy Good Audio Reviews that shows a graph comparing the ZAX with the CA16 at 3:28 of
using the three graphs, I can extrapolate that the CA16 compared to the C12 has even more bass, about 2-3 db, than my C12, so that is actually going in the opposite direction that I want in bass. I'd have to EQ even more than with my C12. BUT, on the positive side, the CA16 is about 3-4 db down in the 1.5k - 2.5k area vs. my C12... That's both good and bad ...that is exactly what I am after at 2.5k, but for sure not what I'm after at 1.5k. Remember I have boosted 1k on my EQ for the C12, so dropping 3-4db just past that is not likely to be to my liking.
One other CCA CA16 issue I might have is the 102db sensitivity vs. the 112db sensitivity of my c12s. I wonder if simply using my iPhone dongle will not be enough to properly power the CA16? With the C12, I am at just about exactly 50% volume with the C12s, and with my Drop/Sennheiser HD58x of 150 Ohm, I am at either 75% or 80% for equivalent volume.
Thanks for the reply. I'm OK with the CA16 by EQing the bass even more down, but the 1.5k suckout of the CCA seems to be in a really important area where the spotify EQ doesn't have any adjustment at all.... and then the 102 sensitivity possible issue.
If I am not able to find a $50ish IEM that doesn't have that 2.5k Hz big bump like my C12, I might just have to bite the bullet and go for the Moondrop Starfield at $110.
CA16 is flea powered. I can vouch for it. One that I still listen to despite having several $200+ IEM, neutral IEM with wide and tall sound stage. Somewhat plasticky timbre though, but barely noticable
