Owludio
I would recommend FiiO BTR3K - excellent BT LDAC + USB DAC with both SE & Balanced. It sounds a lot better than you would expect from BT adapter. It was a surprise to me as I also own BTR5 and given, how good BTR3K is I expect it to cannibalize some BTR5 sales. Also, both LDAC and APTX HD sound so good on it, that I predict that on the go, u would't not bother with USB connection. I know that Google is evil now(they dropped "Not be evil" slogan), and not loved in Europe for many other reasons but I myself year ago left Spotify Premium and switched to Google because of sound quality that I find to be superior on Google. Now for $12(I wonder if Europe makes it more expensive) I get it all: Music, Youtube off-screen+offline+ adds-free+ YT Music . Google play music is supported by UAPP! Also, I find that UAPP makes Google music sound so much better on both LDAC & USB.Hi, first post on the forum but I've been lurking chi-fi threads for years
Anyways, I just replaced my phone and my new one doesn't have a 3.5mm jack anymore. Ouch! I just can't find reasonably priced BT IEMs that sound as good as wired ones I already own. Plus, yet another battery to keep charged... Wired is just less of a headache for me, I'm sure other users here can relate.
I own several chinese IEMs, my favourite ones in my collection ATM are the Tennmak Piano (I know the Pros are an upgrade but those are the ones I have) and the CCA C12 (they do NEED an EQ to boost the mid frequencies tho).
I tried the 3.5mm to USB-C adapter that came in my phone's box and I was very unimpressed with both the clarity and the volume output, when compared to my previous phone's analog output. I then learned that there USED TO be (since I cannot find it in stock anymore) a "direct to" USB-C replacement cable for KZ/CCA IEMs, and I would like to know where I can find one that ships to Europe.
I also ordered a Meizu HiFi non-pro (since the Pro is too much for my needs) but having something I can directly plug into my phone would be VERY convenient.
Also, since I'll be rooting my phone (which BTW is a Xiaomi Mi 10, not the note one, the 5G one) I'd like to know if the mods detailed in this XDA thread are still needed on Android 10 or generally on recent Xiaomi phones. I will not be using USB Audio Player PRO as my main player, as I mostly use headphones on my phone to listen to streaming services or for videos.
Anyways, thank you for your attention and good listening to all!
I also owned Tennmak Piano and gave away them to my friend, who is sound engineer and needed a beater with good mids that sounds kind of like budget speaker system for on the go... Also, doesn't Ali-Express ship to Europe? They have it all!
