Xinlisupreme
I plugged Acoustune HS1677ss to RU6, another fantastic matching!
So happy to chose it, but i'd test M15 also
I am not sure about using the balanced out 4.4mm to RCA input to another amplifier. Won’t this ground the two negative sides of the balanced out circuit? Is this harmful?Hi just pulled the trigger on a RU6. Was just wondering if I can use the 3.5mm or 4.4mm out as a DAC to my darkvoice from windows? Anxious to try the combo of R2R and tubes.
Good point. I am not sure so someone else with the knowledge please chime in! At the moment I am connecting the RU6 to my Aroma A100TB via a 4.4mm to 4.4mm cable. The A100TB has a 4.4mm input.I am not sure about using the balanced out 4.4mm to RCA input to another amplifier. Won’t this ground the two negative sides of the balanced out circuit? Is this harmful?
3.5mm, Darkvoice only support single ended input, you can use a 4.4mm to RCA converter, but it is considered bit risky as can potentially damage the DAC, single ended to balanced conversion is considered fine.Hi just pulled the trigger on a RU6. Was just wondering if I can use the 3.5mm or 4.4mm out as a DAC to my darkvoice from windows? Anxious to try the combo of R2R and tubes.
can confirm the pc volume adjustment works on linux (elementary OS) but not windows.I'm using Linux systems. For some reason you can choose digital or analog.
And yeah you have to find some compatible USB cables for the Cayin. Some will be prone to electromagnetic waves, and others had latency issues.
On my iPad Pro, USB-C out, the iPad volume control has no effect other than full mute.can confirm the pc volume adjustment works on linux (elementary OS) but not windows.
Could I connect this to a cheap dap if I wanted Bluetooth functionality out of it?
So to make sure, my idea is to connect the dap to the ru6 via usb then use the dap as a Bluetooth receiver and stream from my phone. Will that work and is it even a good idea?Get Hiby R2, about $100, and that little dap has 2-way BT and wifi with built in Tidal and Qobuz native apps.
It's a fairly moot point, as both a DAC and dongle DACs both use opamps for output/amplification. The difference is usually that a DAC/amp will have a second opamp/amp stage to increase the current output. Given that the input impedance of an amp will be extremely high, this wont matter.I believe you can but there will be double amping since it is not a true line out. You can use either the single ended or balanced but the advice is to use single ended and to keep the volume at max 70 (this was mentioned somewhere and could be arbitrary but I have tried it without any no issues).
Indeed, use the single-ended 3.5mm output using a 3.5mm to RCA converter cable. That has the most direct output from the DAC anyway.I am not sure about using the balanced out 4.4mm to RCA input to another amplifier. Won’t this ground the two negative sides of the balanced out circuit? Is this harmful?
The answer is buried in one of Andy's posts I think. Usually, you might want to set the volume of the RU6 to minimum, and the Cavalli to max to bypass the Cavalli's volume control. But, if you hear hiss doing that with no music playing, then go the opposite way. Also, if you hear distortion, then the output of the RU6 is too high for the amp and again, you should set it lower and use the volume control of the amp.I just got my RU6. I absolutely love it. I'm hoping to tap into the headfi brain trust for some help. I want to use the RU6 as a DAC with my Cavalli liquid platinum amp. What is the best volume level to use if I am using the SE out to a line level input?
Try this ..worked for me. Got it from Amazon. Also provides subtle sound enhancementhey guys, anyone know how to reduce or eliminate the cell phone noise with ru6? I'm using Samsung s10 plus phone and notice it happens a lot. I'm using stock cable and ru6 with the leather case
thanks but import to Canada makes it almost double in price. I'll see if I can find this elsewhereTry this ..worked for me. Got it from Amazon. Also provides subtle sound enhancement
GUCraftsman USB C Type C to Type C Headphone Amplifier Cable 6N Single Crystal Silver for FiiO BTR5 Q1 Q3 Q3s Qudelix 5K xDuoo Link2 XD-05PLUS E1DA 9038G3 9038S 9038D Lotoo PAW S2¡ https://a.co/d/gTpseA8
