P/P+ adjusts operating voltage, bumping the voltage rails up. It is not a gain control – when you toggle P/P+, there is no increase to listening volume or loudness. Large dynamics become more confidently reproduced with P+, versus the softer, sweeter take that P gives you. You'll be able to switch between the two modes for synergy with different IEMs and particularly headphones.
In single-ended mode, P+ swings go up to seven volts. The N8ii is a bridge-tied load player, and positive and negative phases both function as output. This in particular benefits the balanced P+ implementation to double in voltage swing, and go over 10 volts for a very confident presentation with bigger headphones.
Just remember, P/P+ is not a gain/loudness control. N8ii has a dedicated gain control for L, M and H.
