To answer your question, let's compare the functional diagram of N7 and RU7 when connected to C9, I think that is a good starting point to evaluate the two products from the circuit design level.
The original N7 Functional Diagram is
HERE, and the original RU7 Functional Diagram is
HERE. I redrawn them with similar layouts so that we can compare them conveniently.
When I wrote the original N7
1-bit DAC explanation, I stated that from "
an implementation point of view, the biggest hurdle to implementing R-2R DAC is the extremely demanding precision and temperature tolerance requirements on the resistors. On the other hand, while the 1-Bit DAC technology has relaxed these requirements relatively, it requires a lot of work in noise shaping and is very sensitive to the quality of the power supply", so when we evaluate the quality of 1-bit DAC design/implementation, we should pay attention to these two areas.
The discrete resistor network 1-Bit DACs are the only common points (highlighted in yellow). With N7, the incoming digital audio signal will go through
the FPGA for reclocking (with
two femtosecond oscillators) and reshaping, and the PCM signal will
selectively go through a higher-quality conversion chip handling transcoding and SRC. RU7 will receive the USB bitstream, feed it into the conversion chip, and convert everything to DSD64/128/256 according to the menu setting. Obviously, the N7 offers significantly better D-D pre-processing when compare to RU7.
The RU7 relies on the power from your USB source, and the power will feed the complete RU7 circuit with minimum regulation. The Power Management of N7 is a very sophisticated low-noise highly-isolated supply circuit to support different functions of digital and analog processing separately. I spend 3 days and a lot of discussion with our Engineer to convert their circuit drawing into
a
power supply/management functional diagram. For those who were in this hobby long enough, they should all be aware that power supply plays a vital role in the audiophile hobby, and you probably will be surprised that with N7, Cayin spends more dollars (per unit) on the power supply/management function than the complete digital audio circuit.
The difference (between N7 and RU7) after the 1-bit resistor network is more transparent and noticeable to users. For your particular case, N7 has a discrete LPF circuit feeding a dedicated Line level and Pre-amp out circuit, and the circuit is fully differential all the way through. we have learned a lot from our A02 Audio Motherboard and have improved the implementation when we are not limited by the physical space and power supply of the modular design. This is by far the most sophisticated non-headphone output analog circuit in the Cayin DAP lineup, even better than N8ii in the comparable feature. On the other hand, RU7 runs on a shared PO/LO circuit, so the line out is not a clean output because it goes through the phone application.
In other words, even when we ignored the discrete Class A/AB phone amplifier in N7, the difference between N7 and RU7 is very significant. They should indeed when you consider the price difference. If N7 is within your reach, I suggest you start saving up for the N7.
