- Oct 14, 2013
What battery are you putting in the C9 to get 12 hours at %25 down LOL!
Nothing is wrong with that, I am just surprised that the battery of the C9 was rated at 10-15 hours max, and you used 12 hours to just observer %25 down. That means you can run on 40+ hoursUnit came fully charged and I'm still listening but has now gone down to 2 lights. Something wrong with that? I've done nothing to the unit since receiving it apart from connect my N6ii with A02 and listened through IEM and my Sundara's.
Sometimes when using the ao2 module single ended I get a horribly crackly noise. After a couple of resets it sounds fine. Any idea why this might be? Not a massive problem but a bit annoying. And I've tried several amps and several cables to rule out those parts of the chain.
It's qobuz online and downloaded files....Is that by chance when listening to Tidal streaming online and/or downloaded MQA?
I don’t use SE, so I can’t tell. However, usually crackling noises is due to bad connections. Why don’t you remove the module and make sure cleaning up the receptacles well and properly have it inserted in ? Let’s see if it help ?Sometimes when using the ao2 module single ended I get a horribly crackly noise. After a couple of resets it sounds fine. Any idea why this might be? Not a massive problem but a bit annoying. And I've tried several amps and several cables to rule out those parts of the chain.
I get a 1 second crackling sound at the beginning/start of MQA streamed or downloaded tracks from Tidal.It's qobuz online and downloaded files....
This happens when there is a sample rate change. We'll have to live with it.I get a 1 second crackling sound at the beginning/start of MQA streamed or downloaded tracks from Tidal.
Yes. Saw a thread on this a while ago. Not an issue for me either.This happens when there is a sample rate change. We'll have to live with it.
@Andykong and N6ii users, have any of you with E02 board done any line out connection to a single ended Amp? I am getting a Topping A50s for my desktop rig and despite it being Balanced on the output side, the input are dual RCAs single ended. I can easily DIY my own ICs of 4.4mm to dual RCAs, just don't want to blow up my beloved N6ii
