Thanks for the reply,yes it fine for EDM etc but anything quiet it’s very intrusive.Everybody hears it differently, I know you will ask a dozen of people with that same N6ii and the same module using Solaris or Andro, and they will all hear it differently. When you play EDM or pop or multi-instrument-layered tracks at normal listening volume - you not gonna hear much of hissing. But if you play some instrumental or vocal classical track with a single non-synthesized instrument intro or a drop and at lower volume level, you will hear it more pronounced with sensitive multi-driver IEMs. That's just the way it is. Thus people who say they do or don't hear it, each one is right in their own way relative to what and how they listen and of course their ear sensitivity and hearing level.
@Luke- the only thing I can recommend, switch to using single ended adapter for E02. You can get something as cheap as new DDHifi or ask any cable manufacturer to make a custom one for you. I mentioned in my E02 review that going from balanced to single ended with very sensitive IEMs like Solaris/Andro will cut down the hissing, to make it sound even lower than from E01 directly. Of course, that's relative to how I hear it, but worth a shot if you are willing to try it.
What card do you recommend that’s the least warm ?
I don’t really want to add adapters.
