carpler
- Oct 12, 2013
Mine went away after a reboot. You could also clear the cache and/or turn Bluetooth on and off.
I've had the N5iiS for a few days now - coming from an iBasso DX80 - and I'm very impressed with this player. On first listen, it sounds good to very good but slightly rough around the edges. But after just 18 hours of burn-in it's starting to sound superb: great dynamics, excellent clarity and detailing but none of the infamous 'Sabre glare' in the treble, precise imaging, weighty tone and tight bass - a clear step up in sound quality from the DX80.
However, I have a few complaints and they're to do with the operating system and/or drivers:
1. The latest firmware (1.3) is quite laggy and tempramental. For example, as someone has already noted, when the pause button is pressed - either the physical one or the one in the O.S. - there's quite a long delay (about 2-3 seconds) until the music is actually paused.
The "pause problem" seems not to be solved on my side: after clearing cache and reboot, the long delay (and quick return of music) is come back after the DAP was power on for a while.
The problem seems to be present also on the new N5iiS...
I take this opportunity to report a small problem.
Regardless of the chosen theme, in the "Now Playing" screen in the lower right corner of the cover art is shown the number of the track being played compared to the total of the tracks in the playlist (something like 4/13).
I would ask if this information can be moved outside the image: most of the time the text is not readable, especially if the album cover has quite dark colors.
