samk1234
- Sep 28, 2015
how come?
how come?
You mean why there is no benefit of using SE215 balanced wired? Balanced output has two advantages - increasing a power (since you are sending 2 complimentary balanced signals instead of one referenced to the ground) and reducing the noise (since you are not referencing your L/R signal to one common shared ground). Also, depending on DAPs architecture, balanced output can improve L/R separation for a better soundstage expansion (especially in width of a sound). I don't have experience using Shure products, except for SE846, but in general SE215 doesn't need any additional power and it's not as sensitive or low impedance. Plus, as of now N5 2.5mm balanced output is not dead silent like AK100ii/120ii to begin with. There are other headphones that might benefit from balanced output, but not SE215. If you have your mind set on getting a replacement cable, go ahead. I didn't like SE846 stock cable and not sure if the same goes for their other budget IEMs. Just don't expect to hear any significant sound improvement unless you are getting silver-plated or pure silver or pure copper, etc. wires. That's where a sound upgrade going to happen - changing wires of the cable, not going from single ended to balanced.
Thanks for the info, I'll start looking around for some upgraded 2.5 mm cables. Just so I have an idea, could you describe the difference in sound from upgrading the stock wire to pure copper/silver? I'm curious to see if I would find it a worthwhile purchase
Just want to add that not all users hear a difference with upgraded cables, and the change is usually very subtle. They won't transform your IEM.
And the reason is simple: A cable is a cable is a cable. But people's brains want to hear a difference so that they can justify for themselves to spend 300 or more bucks for an IEM cable.
Alex, I never said others can't hear a difference, nor did I say they don't exist, just that in the order of upgrades cables would be at the bottom IMO.
We all goodI just want people to be aware there is an actual science behind cables
