- Jan 15, 2015
In Chinese... with FB translation that does not make too much sense (to me, at least).is state in the fb
Takes your money and voids the warrantyWhat does the mod do exactly?
u can use messenger ask romi.In Chinese... with FB translation that does not make too much sense (to me, at least).
Hi @Andykong
My humble request to add these 2 safety features to the N3Pro by firmware update if possible:
- Disable auto play after re-boot - Currently the last song is auto play when the device is switched off and on again. Sometimes we don’t realize and it accidentally draining the battery. Also it is dangerous if the volume accidentally increased to very high level while wearing the earphones during the power on.
- Disable volume wheel when music is not playing and the screen is dimmed - Currently the volume wheel is active all the time. Sometimes it can get adjusted accidentally when music is not playing and caused inconvenient to re-adjust. It can also cause loud sound damage to the ears if it’s turned too high volume without realizing it the next time the music is played.
Stay updated on Cayin at their sponsor profile on Head-Fi.
Does any one know what kind of cable I need to connect the N3Pro to desktop amp such as Schiit Asgard 2 and Topping A90? I plan to use N3Pro as dac for these amp to compared it to Modi 1 for driving hard to drive full size headphones.
As mentioned above, this usb-c to rca coax cable will do the trick.
N3ProDX160 or N3Pro? I went through the whole thread and coudn't get the definitve answer.
Actually I was using "Native" option. With DoP It seems to go up where It Is supposed to go, tnx.
P.s. I have to rethink about 4.4 output... With my Audeze Isine 20 It goes out pretty well in the end..
4.4 output vs 4.4 output yes. But you'll want to stick with the 3.5mm output on the N3 Pro for better sound quality. And in that case the DX160 will be over twice as powerful.
This won't work, Schiit Asgard 2 and Topping A90 are analogue only, they don't have coaxial input.
Finally have some time to "double-amp" N3Pro+BX4.
N3Pro LO > BX4: tube sound leaner, but sound stage wider and cleaner. Turn up volume past 2pm and the sound can be distorted.
N3Pro PO > BX4: tube sound lusher, sound stage narrower but background darker. N3Pro volume at 100, BX4 past 2pm or even 3pm, still no distortion.
Thank you very much for your suggestion.
1. You can disable auto resume. At Music setting, select Breakpoint resume, select OFF.
2. I play around with the volume knob tonight and cannot figure out the dangerous condition you have suggested. Have you run into similar situation so far? The volume knob of N3Pro has two metal guards and these will limit the movement. If you move the volume knob by simple up and down movement on the side of the knob, you can only change +/3dB in one move.
Maybe you can illustrate your point by providing a video to how us how you can increase or decrease the volume significantly (e.g, 10dB) in one continuous move towards one direction.
