Got my unit today (long story) also.
No issues for the first few hours (sounds magnificent, looks better in person).
Then, all of a sudden, distinct hiss in the left channel - audible over the music that was playing (and for about 5 seconds afterwards if I paused playback).
That was in low gain, P, class A, classic tube mode and was present regardless of playing from TIDAL, Qobuz and local files (SD card) via the Cayin app. Was still present, at the same level in modern tube and solid-state modes. Switching to class AB lessened it (more static than hiss) and moved it to the right channel.
Powered off, let the unit cool for 20 minutes or so, powered-on and so far no hiss.
Might be software? Might be thermal? Unit was playing in its case and running over 105F measured from the screen.
Not encouraging ... definitely keeping an eye/ear on it.
And ... the hiss/static is back ...
Removed the unit from its case. Temperature is back up to 111F (measured with my IR wine thermometer, so not the most accurate instrument - but the best I have to hand since I am traveling). If it is a thermal issue then it's basically borked - the only lower-power mode would be class AB and it does it there too once it starts.
Don't think it's software, as it continues until the amp powers off after stopping playback (about 5 seconds).
Still present with WiFi turned off.
If it was cable-related, it wouldn't be intermittent (could be an issue for anyone experiencing it from cold).
Not good.
Not sure what an acceptable remedy will be absent an immediate unit replacement; highly disinclined to wait an indeterminate amount of time for diagnoses, repair and a whole lot of shipping nonsense on a buggered-on-day-one unit.
Tested again in purely solid-state mode (i.e. tubes not engaged at all after a power-cycle and cool down). The hiss/static still shows up, at a slightly lower level (still audible while playing music) - after about the same amount of playtime/unit temperature.
I'm not convinced it is a thermal issue: correlation != causation - but it is interesting that it only seems to occur over 100F. Once it starts, though, it doesn't stop just because the unit cools down a bit - has to have a power-cycle on it too.
I didn't find any evidence metal specs anywhere, including in the sockets. Can't test the line-out at the moment.
Going to give it one more try and see if anything changes (e.g. level of the hiss reduces, or doesn't show up again at all), and if not I guess it'll have to be replaced.
This is new to us. Just to summarise your observation, the noise pattern is triggered by a thermal condition, and it can only be resolved by powering off and on again, idling the DAP to lower down the temperature will not solve the problem. We haven't received similar complaints from other N30LE or N8ii users so far.
I can't determine whether this is a hardware or software-related problem at this stage. I have several questions that can help us to narrow down the problems. If we can confirm that the problem is software-related, then we should be able to resolve the problem without going through the logistic hazel.
(1) You mentioned Class A in your description, what about Class AB? Set the player to Class AB with P+ mode, the player should reach 100/110F like Class A with P mode.
(2) Are you using 4.4mm phone output exclusively? or 3.5mm? Have you compared 3.5mm vs 4.4mm PO? Assuming you are using a 4.4mm phone output when you encounter the noise problem, if you switch to a 3.5mm earphone, will it display a similar noise problem?
(3) What are the earphones/headphones involved when you hear the noise? Have you tried multiple earphone and headphone and the noise are less prominent or only show up with one or two earphone/headphones? If that is the case, I need to collect your earphone/headphone list and try to correlate the noise problem with the impedance and sensitivity loading.
(4) I need to pull out the QA record of your DAP, I'll drop you a PM to collect your DAP and dealer information.
Stay updated on Cayin at their sponsor profile on Head-Fi.
