Hello everyone,
It's my first post on this board, and I'm kinda new to the hifi world, so maybe some part of my post will sound dumb or maybe I won't use the right words.
I bought this amp 10 days ago (new).
I chose it because I want to be able to use high impendance headphones, like the 600 ohms ones from BeyerDynamic. But I'd also like to use low impedance headphones (like a Grado GS1000e), on the balanced output.
At the moment I only own an AKG K612 Pro (120 ohms). This heaphone is plugged on the low impedance unbalanced output of the amp, with low gain and low current.
During the firsts days, I had no issue with the amp at all.
Since a few days, I start getting some kind of static noise, that I can easily hear in the headphone. When I turn on the amp, it's fine during maybe 10 mins, then the static noise starts to happen. It can happen when I'm doing nothing at all, but it can change when I touch or wrap the headphone cable, or when I play with the volume knob of the amp. If I turn on the high gain, or the high current, the static noise goes away. I also tried plugging the headphone on the high impendance output, it seemed okay. I didn't try the balanced output, since I don't own a balanced headphone yet.
This static noise happens even when no source is plugged to the amp.
At the store where I bought the amp, I was told that this static noise could be a ground loop problem, but that it should be amplified/louder when I turn on the high gain, not disappear.
I tried plugging the amp on another electric outlet in my home, where there's nothing else plugged; I tried turning off things like my fridge or my water heater, since I was told it could mess up with the power. But same result. I don't own a power conditioner or a power regenerator, to test if that could help.
So I'm gonna go to the store with my amp, so they can test it themselves. They told me that if they can reproduce the problem, they would replace the amp directly with a new one (instead of having to wait for a repair). But when I look at the latests messages in this thread, it seems the problem I have isn't uncommon, so I'm a bit afraid I might get another amp with the same exact problem.
I only owned things like USB sound cards before, and a Topping L30 (that I had to send back), and I never had this kind of problem, so I'm not sure about what I should do.
Thank you.
