PinkyPowers
Reviewer: The Headphone List
Nope but I use the Mometum 2.0 overear bluetooth but I have not tried it yet.
You're as bad as me, just enjoying the i5 for its great sound and forgetting about all those extraneous features.
Hey guys, I bought my Cayin i5 a month ago and so far I have been really enjoying this DAP. I normally use it for 2hrs a day. It´s a musical sounding product that retains lots of details and resolution across the spectrum, and it´s packed with a wide range of features (Wifi, streaming services, Bluetooth, USB DAC, OTG) which the i5 performs correctly most of the cases. Yes, some of the features have minor bugs or issues that will certainly be solved in future software updates but so far is a great product.
Yesterday I experienced the first “abnormal behavior” with the i5 since I bought it. An issue I thought it was worth mentioning here and ask if any of you have experienced the same. It goes beyond the typical bug issues in user interface. A day ago I charged my i5 to full charge using the stock cable that came in the box and my iPhone 5S power adapter which output is 5V at 1A. It usually takes from 3 to 4 hours to fully charge the Cayin i5 battery. Later on I decided to hear one of my favorite albums (A masterpiece IMHO), Mozart Violin Concertos (MQA Remix 2016) which I have on DSD128 and paired my i5 with my AAW A3H Pro in order to enjoy such album. The battery went down from 100% to 75% once I finished using my i5 and then I turned it off and I went to sleep. Approximately 18 hours later I tried to turn on my i5 to enjoy music as usual but I noticed it didn´t turn on. I tried 3 times to turn it on (Pressing the power on/off button for 3 seconds) but nothing happened. Then I tried to charge the i5 with the stock USB cable and the power adapter for about 8 minutes but nothing happened (the charging screen didn´t show up when the i5 was plugged to the electrical source), and after that I tried again to turn on the i5 unsuccessfully. Finally after my failed attempts to turn on my Cayin i5 I decided to enter recovery mode (pressing down power on/off button and the key button at the same time for 5 seconds) and finally! The i5 turned on. Once it turned on I checked that everything was working as normal but I noticed that the battery was at 36% instead of the 75% I left it the night before.
Has this issue been notified here on this thread before? Has anyone experienced this same behavior? If so please reference me to the page were this issue was discussed.
I don´t believe I left my Cayin i5 accidentally turned on and playing music because if so, the battery would have drained completely and second, If I left my i5 turned on but without playing music the battery would not have drained a 39% in the 18 hours I didn´t use it. Finally, neither of the aforementioned cases that could justify the battery drain could not explain why the i5 was unresponsive when I tried to turn it on.
As a side note, I normally play music directly from the SD card or the internal memory on the i5 with the Wifi turned off, Bluetooth turned off and in low db.
So far my listening experience with i5, apart from the fact I still haven't got decent headphones to pair with, is very good, and I havent't experienced any issues with wifi streaming, both with Spotify at highest music quality, and with streaming over my lan.
I have two minor noob questions:
1) do the play/pause and skip track on screen buttons when the screen is locked work for you?
2) what is the gain settings for?
Dang! I would have suffered a heart attack if I had experienced that... Now on a more serious note I haven't experienced anything like that.. :S Are you completely sure you turned the device off when you went to sleep? I've forgotten to turn it off several times after listening to something at night.
I experienced it twice if I remembered correctly but was almost 1-2 months ago.
I almost suffer a heart attack!! lol. I have been thinking about it for a while and actually I don't know if I turned it off when I went to sleepI might have left it playing music during the night, but I still don't know how or why the device became unresponsive even when I plugged it to the power source 18 hours later I went to sleep. The aforementioned scenario makes me ask the following question:
Which would be the normal behavior of the Cayin i5 if it is left playing music for 4 hours straight, and after that it stays on for an indefinite period of time?
I'm tempted to replicate this scenario to see if I can replicate this "abnormal behavior". @kel77 would you elaborate your experience? Did your i5 also became "unresponsive"?
