rulerofrecords
I did try most of that, RCA - XLR switch etc etc - what I did hear was a very slight hum. Yeah I'm not gonna speculate here. Only thing that does already bother me that the dealer I bought from is not sending the amp to Cayin in Germany for service - but to some "tube guy". I do not like that ...From my understanding. If the tubes are glowing the fuse is ok. The problem is in signal path before the driver tubes or at amplifier tubes stage. May be simple contact disconnect in XLR to RCA switch button. Did you try XLR and RCA input? And also did you play with 6.3mm, 4.4 mm and XLR output button and connectors? Even without signal, did you hear the some extra noise On headphone when turn the volume up? If yes, so the amplifying stage is fine, means the signal is not coming to the preamplifier/ driving tubes stage. Assuming you was in right headphone output and input (my guess)? Did you try to connect and disconnect RCA input at working amp with headphone in? You should hear the loud pop noise when disconnect or connect. For me it looks like wrong or faulty connection issue. Regards, Kim
