ArkNerevar
...yes I know that, im just pointing out youve stated NOS as being a DAC topology, when I think you meant to say R2R/Multibit type following ESS Sabre & AKM (D-S).
My cage doesn't fit over my SE KT88s. Are you using something to raise the cage at all or did the revision sink the power tubes in deeper?Been doing a burn in since this morning and I just love this amp. One of the very few times where I had high expectations and had them surpassed. I had the replacement tubes already here (SE KT88, SEE 12AU7) so I just moved into those. So far impressions
Meze Elite - Sounds incredible. I loved the Elite with the GS-X Mini already but there's a bit more warmth, depth and boominess which I didn't feel I was getting with the GS-X Mini.
ZMF Atrium - Thinking I'm just not a Atrium Open fan, didn't really like it on my GS-X Mini and don't really care for it on the HA-6A either. I just don't see a scenario where I'm going to pick this up over the Elite, think I'm going to list it for sale which I hate because it's just a gorgeous headphone.
Elysian Annihilator - This was easily the biggest surprise. Need to spend some more time with it but I can't believe how punchy these sound now while maintaining the treble and detail.
Sophia Electric KT88 have a bigger bottle than regular KT88.KT88s fit under mine, but anything with adapters doesn’t, so I use 4mm banana adapters to raise it higher when I need to
not using anything additional, cage just fitMy cage doesn't fit over my SE KT88s. Are you using something to raise the cage at all or did the revision sink the power tubes in deeper?
very odd. Cage fits over with at least 1/2 inch of room to spare.My cage doesn't fit over my SE KT88s. Are you using something to raise the cage at all or did the revision sink the power tubes in deeper?
Do the current models come again with a pair Gold Lion KT88 in the wooden box?
What a shame.I got one of the ones with the newer rectifier 17ax4 rectifier tube and it only came with EL34s.
i got mine in like a week ago and it did notDo the current models come again with a pair Gold Lion KT88 in the wooden box?
Do you like your new amp so far? any hiss or hum?i got mine in like a week ago and it did not
Great so far. Upgraded the tubes to SE KT88 and SE 12AU7 as well. Sounds great with the Susvara and has plenty of headroom which is what I was hoping for.How do like your new amp so far? any hiss?
I'm looking beside the TAD KT88-STR Redbase for good driver tubes, for a lush and full midrange - can you tell me the exact name of your SE 12AU7 tubes?Great so far. Upgraded the tubes to SE KT88 and SE 12AU7 as well. Sounds great with the Susvara and has plenty of headroom which is what I was hoping for.
