Yes i have 2 week for return HA-6A.
i highly suggest you wait and cancel your orderI do it, i receive 8 june, but now i'm afraid because there is a hiss output, maybe i delete my request.
its not loud but it is there , to me at this state is unusable , if not fixed i will return it back , i dont think it is a power issue , it is voltage issue , mainly dynamics with all impedance's has the hiss .Reading through the thread has left me wondering how loud the hiss is, it seems like it’s only with the balanced output.
Considering the balanced lowest power output 1000mw and can reach 4500mw (depending on tubes and setting) It doesn’t seem that unexpected to me.
On my 1A-HA mk2 I never even go to half volume... maybe I should consider something with less power
seems my hope to own a OT tube amp is not happening again....its not loud but it is there , to me at this state is unusable , if not fixed i will return it back , i dont think it is a power issue , it is voltage issue , mainly dynamics with all impedance's has the hiss .
if i understand, it is only on the XLR output that there is the hiss? on the 6.3 jack output there is not this hiss?
Stay updated on Cayin at their sponsor profile on Head-Fi.
Yeah they pulled it out few days ago , i ordered mine before that, and it is from Cayin china directly, hiss is very clear , problem is that i dont have other tubes , i am expecting new ones within next 2-3 weeks, hopefully Cayin will wait for me to try the new tubes otherwise its going back, crazy thing i was looking for an amp that can power planers and then changed my mind to dynamics, so i thought the HA6A with lower power rating than the HA300 , would be more suitable , this amp can power anything easily, it has crazy amount of power, i cant imagine how is the HA300.All this talk about hiss is concerning with this amp. I wonder if this is why it’s no longer available on Musicteck’s websight? I hope it’s being addressed by Cayin. The balanced output should be more quiet than the SE output in normal situations.
its in both output but it is very high in the balanced output ..if i understand, it is only on the XLR output that there is the hiss? on the 6.3 jack output there is not this hiss?
Based on a sample of 1 (my buddy's HA300) - no hiss at all. Been a while since we met (thanks COVID-19...) but I really was impressed by the HA300.i thought the HA6A with lower power rating than the HA300 , would be more suitable , this amp can power anything easily, it has crazy amount of power, i cant imagine how is the HA300.
on earlier HA300 forum, some also had hissing issue.... think they've fixed it by now.Yeah they pulled it out few days ago , i ordered mine before that, and it is from Cayin china directly, hiss is very clear , problem is that i dont have other tubes , i am expecting new ones within next 2-3 weeks, hopefully Cayin will wait for me to try the new tubes otherwise its going back, crazy thing i was looking for an amp that can power planers and then changed my mind to dynamics, so i thought the HA6A with lower power rating than the HA300 , would be more suitable , this amp can power anything easily, it has crazy amount of power, i cant imagine how is the HA300.
Thank you very much for the care and support.Let me help you to trace your case, I need the serial number of your HA-6A, will send you an PM to start the follow up process.
