heyguyslol
I have been using the SE RCA inputs on my 3A but I recently ran a comparison test of the BAL XLR inputs and noticed nearly a 10dB increase in volume. As far as quality goes; I still need to run more tests as it was very brief but this may be something you want to consider when doing your testing.Thanks I will order the unit this week but I just wanted to make sure it has the power. I have the Schiit Lyr + but I have had 2 units fail on me in the space of 2 weeks so I am done with that amp now. The Lyr + has an amazing sound on the tube mode but it just kept failing and not working so I want something that will sound even better and that will work without issues.
I didn't initially test this because the 3A doesn't support true balanced inputs as it has its own built in converter to convert the XLR input signal back to a SE input. I was told this can potentially lead to degrading the quality of the signal but as stated I need to run more tests to weigh the pro's and con's for my use case.
If I do end up switching to XLR inputs I'd be able to lower my volume usage (11pm to 9-10pm) quite a bit to a near black background which might also allow me to take advantage of the XLR outputs as my previous cfg was a bit to noisy w/ my environment which left me only able to use the SE & 4.4 outputs.
Additionally, Zach has said that he sometimes uses a XLR to RCA Balanced converter from Amps and Sound
https://ampsandsound.com/products/xlr-to-rca-converters
So this might also be something to consider as an addon later on down the road.
gluck
