Do you know of a good European based source for these? Are all 5814(A) are the same? Tube business is really confusing. ![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
The G73R is anything but dry, and sounds unlike all other Telefunken's. I know you are a serious tube guy just like myself, and if you can swing the cash the G73R is incredible. I can't even really put it into words how otherworldly this tube is, and it really can't be compared to any other 12AU7 variant sonically.I would love to own a pair of RFT 6sn7 for my Euphoria amp. Sadly prices are crazy.
Those RFT 6v6 come in two different constructions but both sound tremendous! Absolute reference sound. Vintage is 1954.
Does the G73R sound like a Telefunken Ecc802s? I heard they sound quite dry and sterile ? I might be tempted.
I have Telefunken smooth and ribbed plates Ecc82. Ribbed plates is a little warmer than smooth plates. Still not neutral like a Mazda ecc82.
Strong recommendation. Pewder plates also come with GE label. Sometimes they are available dirty cheap in NOS condition.
I must admit holygrail 12au7 tubes don't have an incredible benefit to the sound on the Cayin HA-3A to swing 1000€ for a pair.The G73R is anything but dry, and sounds unlike all other Telefunken's. I know you are a serious tube guy just like myself, and if you can swing the cash the G73R is incredible. I can't even really put it into words how otherworldly this tube is, and it really can't be compared to any other 12AU7 variant sonically.
According to this page 5814 at tubeworldexpress that was a silly question.Do you know of a good European based source for these? Are all 5814(A) are the same? Tube business is really confusing.![]()
Take the bottom off, see what might or might not be in the way and drill and tap for new feet or use some stick on with good double sided tape.Any owner happens to know if you could potentially change the 3 feet to 4 feet on the HA-3A (e.g. threads are prepared on the bottom) since I am not a huge fan of the 3-legged approach on audio devices?
From a stability point of view it is unnecessary. Most of the amp's weight sits on the rear two feet, and the whole amp is pretty heavy; 12 kgs. It takes quite a bit of force to move it out of balance. If you prefer 4 feet from an aesthetic point of you, that is a different story.Any owner happens to know if you could potentially change the 3 feet to 4 feet on the HA-3A (e.g. threads are prepared on the bottom) since I am not a huge fan of the 3-legged approach on audio devices?
Why are all tubes called Blackburn ? That should be the factory of Mullard. Did you buy several relabled Mullard pairs ? They can come as Mazda, Tungsram or RTC but mostly have "made in Britain" print on them.RCA Blackburn
RCA Dario Blackburn
Phillips Blackburn
Mazda Blackburn
Valvo Blackburn
Yes you got me there. For the prices I can't resist.
Making a shootout for Cayin tubes is a little bit more difficult than for my Euphoria as due to the transformer coupled nature (I guess) of the Cayin you don't hear changes in resolution and staging. So tubes really only color the sound of the amp and it's harder to find real synergistic combination as the technical synergy is missing. That makes it even more subjective as describing sound already is.
I have quite a lot 12au7 and 6v6 already, so it will take a lot of time until I will find the best combinations for my taste.
12au7 seem to have more impact. 6v6 sound is more subtle than I am used to for power tubes on my Euphoria.
This overview is helpful.
I don't always have the same vintage. My 80s Mullard boxed plates sound amazing in the Cayin. So I wouldn't worry about the vintage here.
Construction is more important. I have 4 pairs of RCA 12au7 with different plate structure and they all sound different.
Even with the stock tubes this amp blows my mind much more than all of it's predecessors of which there are many, the depth of the sound, the harmonic distortion, the imaging, I listen to mostly prog rock and soul and reggae, I know Worlds apart but I consider my mind blown with every song, the stock tubes are great with a little roughness around the edges (nitpicking) but they are under 50 hours so room for improvement, sorry to deviate from your question but I have no experience with the woo audio stuff but pound for pound I would say you can't go wrong with this amp, as for drivability they handle anything from my Cleer next 16ohm through HD800, HD820 to the T1 with easeHas anyone compared this to a WA6SE? Thinking of this amp or WA2 or WA6SE for Verite Open.
Thank you. I am looking at this and HA-6A as well for planars.Even with the stock tubes this amp blows my mind much more than all of it's predecessors of which there are many, the depth of the sound, the harmonic distortion, the imaging, I listen to mostly prog rock and soul and reggae, I know Worlds apart but I consider my mind blown with every song, the stock tubes are great with a little roughness around the edges (nitpicking) but they are under 50 hours so room for improvement, sorry to deviate from your question but I have no experience with the woo audio stuff but pound for pound I would say you can't go wrong with this amp, as for drivability they handle anything from my Cleer next 16ohm through HD800, HD820 to the T1 with ease
