To me basically all the NOS tubes I tried so far sounded a bit smoother/more natural around the edges.I really find the stock tubes to be a little rough around the edges with a bit too much distortion, can anyone recommend a good tube combination that would smooth out the sound a bit, overall I love the depth and clarity of the amp, I do realise that it's a tube amp and that the distortion is sort of the point
If you use both the XLR and RCA output on some DACs, the voltage can drop which impacts output performance (even if the interconnect cables are just plugged in to two amps). It is worth checking if this would be the case with your DAC of choice.Has anyone noticed performance quirks, or sound degradation when using the balanced input and single ended output?
I'm looking at a new DAC and will use the balanced out for the 3A, and the single ended for my Valhalla so I don't have to swap cables all the time.
I use XLR input on the 3A and works perfectly with the SE out, but I personally prefer XLR out on my setup as it sounds a tad more spacious and clear to me. Others prefer SE out.
