I have had a similar experience, static noise mostly in the left side. Swapped tubes around but same problem. I noticed strong micophonics in the power tubes. I eventually purchased new power tubes and so far no reoccurring issues. Not sure why the power tubes failed. I may have left the amp on for a while with no phones connected, can’t truly remember, apparently this can cause potential problems including tube failure. Bit new to tube amps so not really sure what has caused this problem, hopefully your problem is just tube related & can be easily solved, good luck
For Cayin tube amplifier products, theoretically, this will only age the components gradually. For the record, we have added extra preventive protection measures to the output of our tube amplifier products to prevent any damage to the tubes and output transformers when our user power on the amplifier without any loading (i.e, no headphones connected in case of HA-3A, HA-6A, and HA-300MK2).
Having said that, when the tube headphone amplifier is turned on without plugging in the headphones, the transformer and components in the machine are still operating. All electronic components, including vacuum tubes, have a limited lifetime, if you keep the amplifier running like this, it is equivalent to consuming the life of the components, so we do recommend our users to turn off their amplifier when not in use.
Stay updated on Cayin at their sponsor profile on Head-Fi.
