Thank you
@donato for point this out and
@llamaluv for recovering my previous suggestion. I didn't aware of the discussion about speaker tab connection until today.
I must remind everyone that HA-300 is an amplifier purposively designed for headphone application, with speaker output as value-added feature. This is very different from generic integrated amplifier with speaker as primarily output and headphone as value-added feature. For example, with Cayin tube integrated amplifier such as CS-55A or MT-35 MK2, the headphone output is an amplification that is independent and much lesser output from the speaker output. If you compare the different output value of HA-300, you should notice that the speaker output is actually a lesser output, especially when you use a higher impedance setting. To illustrate my point, I have provided a table with to compare the output at VRMS, with the R value as an arbitrary impedance loading that is close to the mid value of the Low, Mid and High impedance setting respectively. For the record, the Mid impedance Balanced output of HA-300 is more than doubled the speaker output already, so if you want more power, stick with the balanced phone output.
As others has pointed out, Verum is not a very difficult load according to its specification. Verum is very different from other planar headphone because of its extremely low impedance rating, at 10 ohm. It is very close to the 8 ohm fixed impedance loading of speaker output. With planar headphone, the impedance will affect the sound signature significantly, and that's why Cayin developed impedance matched output features in our tube headphone amplifier. In the case of Verum, the impedance is very clos to the speaker output, that's why it sound "better" with speaker output. If you have a low sensitivity planar at 24ohm or above, Cayin do not recommend using the speaker output. You can explore with caution, but we don't recommend this officially.
