ken6217
Yes. Very helpful. Thanks so much!
I would like to use my preamp, the Rogue Audio RP-7, as the source input to the HA-300. I want to avoid having to physically swap interconnects on my DAC every time I switch between using the HA-300 and my power amp. The preamp allows me to switch between outputs at the push of a button. Before I try this, would like to find out whether it is safe to do so given that the RP-7 has quite a lot of gain (20db via XLR). Would there be issues (safety or otherwise) with connecting my preamp to the HA-300?
To help, these are the specs for the RP-7:
- Tube complement: 4 x 12AU7/ECC82 tubes
- Frequency response: 1Hz – 100KHz +/- 1 dB
- THD: <0.1%
- Gain line stage: 14 dB (20dB XLR)
- Rated output: 1V
- Maximum output: 30V
- Output impedance: <10 Ohms
Appreciate any advice I can get on this.
Stay updated on Cayin at their sponsor profile on Head-Fi.
The maximum output of RP-7 is 30V, that is quite a lot when compare to the standard XLR line output of DAC (4V in general).
However, this is maximum output only, I don't suppose you'll turn up the volume kof your RP-7 to maximum even with your speaker. So its a matter of setting the volume (or output) of your PR-7 to an appropriate level when you use it as the source of your HA-300. I recommend the following procedure to determine the suitable volume setting of PR-7
- Connect your DAC to HA-300, preferably in XLR, plug in your favourite (and most familiar) headphone.
- Play some familiar tune and set the volume to your preferred level.
- Keep the volume level and setting of HA-300, turn it off, and now connect the DAC to PR-7, and then connect PR-7 to HA-300 in XLR.
- Turn the volume of PR-7 to 0, power on the PR-7 and HA-300.
- Play the same music files/CD again and gradually turn up the volume of PR-7 until you reached the same sound level from your headphone. This is one of the potential volume setting of PR-7 when serve as source of HA-300. Make sure you don't change anything on the HA-300 during the test.
- Now repeat the process with a different headphone, and arrived at the second set of potential volume setting of PR-7.
- If these two setting is vastly different, you might need to repeat the test with more headphones. Otherwise you can use the mean of the two potential volume setting as your final volume setting when connect PR-7 to HA-300
I just think the top 5-10 volume steps (out of 24) are unlikely to be useful for most people, outside of maybe Susvara or HE6 type headphones. And there's a gain switch as well... so I would expect a full range from "barely audible" to "way too loud". And HA-300 does not accomplish that.
I find it odd that your amp plays this way and I play mine at approx 50% up in the volume knob,
even taking into account volume preferences. My DAC outputs 4V which is pretty standard.
