As a fellow neophyte 300B amp owner, 100% agree. On this amp you just cannot tell from looking at the 300B tubes whether or not they are fully seated. Whereas with the 6sn7s you can look from the sides and the front to determine how much more work you have left to do.I think that a note stating that the 300B tubes need to be pushed down to fully seat them is inadequate. When I received my Cayin HA300MK2 amp, I did push down on the 300B tubes with the intention of fully seating them, but it didn't work because I was not applying sufficient push-down pressure. I was flabbergasted at how much push-down pressure I really had to apply to fully seat them and I learned from my mistake. A neophyte 300B tube amplifier owner does not have any subjective experience of how much push-down pressure is needed to fully seat those 300B tubes and I think that he must have a better method of knowing that the 300B tubes are fully seated by confirming that the ends of the 4 pins are being firmly grasped by the tube socket's mini-clamps.
Jeff.
However, unlike the 6sn7s these will "pop" in and out making an audible sound and sensation when seating and unseating. So what works for me to ensure the 300Bs are seated is to first remove the tubes completely at the base pulling straight up. Then line up the pins per the manual pressing straight down until it "pops" or clicks in.
When I find myself pushing pretty hard but its not "popping" in then I'll stop, take it completely out again, re-line up the pins and try again. Usually on the second or third try it will more easily pop in at which time they're fully seated. Once I got used to how this works its actually easier for me than the 6sN7s, which are a major struggle to get fully seated, and often require first removing the 300B tubes to get my hands in a better position.
