Suddenly HD800 is all over the thread, I'll try to response them in one post.
Did I vastly limited the applications for the C9? A lot of people don’t just search any further? I don't really think so, but if this really happened, I'll continue without hesitation. To be honest, I have shared similar thoughts previously (e.g.
HERE), I am pretty consistent in steering people away from using HD800 for portable.
To me, using HD800 with battery powered portable amplifier is workable, some portable amp are better then others for this scenario, but please accept the reality that there are limitation you can't solve by more money. If you only listen to "simple"music, with one of two instrument that does not required a lot of dynamic (bot macro or micro),
First of all, those who try to work out the power requirement of HD800 based on electrical engineering principles and specification, I can tell that you know nothing about HD800, or the real game of headphone/amplifier synergy. The reality is, the formula only tell you how much power you need to make is sound loud, but that is not our requirements, right? We want to hear it sing, not to hear how loud it can go.
The biggest problem with battery powered headphone amplifier and HD800 (or 300ohm headphones in general) is insufficient voltage swing. The impedance ranges of HD800 swing between 340 and 650 ohms (
HERE), to handle this kind of impedance swing, you amplifier must have very respectable voltage swing. So what kind of voltage swing can you achieve if your amplifier is powered by one 3.7V lithium battery? Sure you incorporate DC to DC regulation circuit to boost the voltage to 10V, 20V, 30V, but experience amplifier builders will tells you that there are procs and cons in using booster circuit, especially when you are going for 20x or 30x voltage gain. The biggest question is, can the booster circuit response fast enough? will it compromise the transient of the playback? In desktop implementation, we can install arrays of capacitors as buffer to support short-term power requirement, the capacitors are not expensive, nor are they difficult to implement, but they need space to start with, something that portable headphone amplifier are lacking.
To certain extend, the power supply of C9 starts at a much better off situation. The four 18650 lithium batteries are connected as a ±8.4V (i.e., 16.8V) battery power supply, this is significantly higher than the commonly used 3.7V USB rechargeable lithium battery. We don't incorporate any DC to DC regulation circuit in our power line, making sure the power supply is direct, extremely fast responding and noise-free.
Yes, we are better than many portable alternatives, but still, when compare to ±24V power supply with a dozen of 20000 uF electrolytic capacitors (just make up some numbers for comparison purpose, please don't take it specifically), C9 is in a very disadvantage position.
There are other factors that makes HD800 or HD800S difficult on portable environment than other 250 ohms or 300ohms headphones, for example, its unique sound signature, huge soundstage, and music genre that are frequently associated with them, ... just to name a few. These I don't want to turn this thread into a HD800 mix and match thread, so I'll stop here. I hope I have make my point: the problem is not whether C9 has enough output power to drive HD800 to 96dB, its the voltage swing that matters, and low-voltage battery powered amplifier has a congenital defect on this issue.
