Selling my C9 with Leathercase if someone is interested (EU), it has a fantastic sound.
It's almost new and I've used it for no more than an hour. Listen again with Desktop Setup.
hi, I am looking to connect the C9 to my Eversolo DMP A6
I have attached a picture below to help. I am already using the XLR connections with a Topping A70.
Not only too hot- the issue is that there could be shared ground in the connection that will short circuit and fry your amp. Pls check page 48, post #719 of this thread and if still unsure, PM @Andykong from Cayin or perhaps he will weigh-in here. Every DAC is different, and it may be ok, as long as you donโt charge the C9 while you are connected to the DAC and playing music.
Cayin will celebrate its 30th Anniversary on August 2023, we shall launch FOUR 30th Anniversary Limited Edition products in the second half of 2023, one of which belongs to the "Personal Audio" category.
Andy, are you posting it here so we can expect a new C9 version with a DAC inside, an R2R or 1-bit DAC maybe? That would be quite an announcement. I know you can't answer this, I'm just teasing you.
To compete against others like Woo WA8, iFI Gryphon, and others. Many people these days have all their music on a phone or stream from a phone so pairing it to a top ยซ transportable ยป dac-amp makes sense to those people versus buying a DAP. As you said, wishful thinking!
I received my C9 today but it will not turn on.. I believe that the battery module may have gone into the Protection Mode..
However, I could not seem to disable the Protection Mode, even after following the steps in the thread..
I have done the followings:
1. Removed the battery tray and batteries
2. Connected them to a USB charger where the fourth LED (below H) blinked for 10 seconds
3. Inserted the battery tray back to the main unit
4. The C9 still would not turn on..
