- Oct 14, 2013
The C9 is true Balanced Amplifier. Of course it can take single ended input and output inverted phase into balanced out.I am fairly new to topologies and this "pre" option kind of confuses me.
Anyway, I use a Hugo2 with an r6pro as a transport. Now, this is what I want to do. If I only use my Hugo2 DAC and feed the signal to the c9 (note that Hugo2 is single ended), so it makes sense to feed SE to the c9 here. But most of my gear are 4.4mm terminated. With this setup I mentioned, what comes out of the balanced phone out of the c9? Clearly, the input is not balanced, but can it output through the balanced socket to the headphone/IEM (I know theoretically it won't be balanced) but I am just doing my research before shelling out the money.
Therefore, you should be able to use it the way you just asked
