bluestorm1992
DAPs like DX300 are beats in terms of functionality.Can't play Angry Birds with my Dunu Lunas on Astell and Kern DAP.
AK is already behind.
I notice that the C9 gets quite warm. Are others using some kind of feet to get some airflow underneath?
I put furniture feet on the bottom of mine, they go on top of the protector film that's still on so there's no adhesive residue leftover when/if I get a case later on (just remove the film).I do. In fact, I actually put rubber feet on the case, assuming that if the heat causes them to leave any adhesive residue, I'd rather replace a case than mar the finish on the C9.
FiiO had an interesting and honest post a few months back about their strategy/roadmap as relates to DAPs.N6ii Titanium will be competing against AK SE180 I think ?
This is interesting as a Known Lixurious brand has brought itself down a few levels to compete to Cayin, or Cayin has brought itself up a few levels to compete against AK. Could be both
However, it is very interesting to see the direction this hobby is heading toward
Also doubled-up command strips to create space between the amp and DAP and keep airflow there. These also hold really well and leave literally no residue when removed.
Seems ghetto for the gear but Empy + C9 = no money left for fancy leather case
All jokes aside it does actually work well and neatly. I'll have to swap those white command strips in the middle for black ones so my OCD doesn't go too crazy.
I was thinking of ordering a longer cable to.I bought some cupboard bumpers but I think I might get something a little taller.
I wish the cable was a as bit longer as my M8 has the jack on the top.
On the heat issue recommending one of the Cayin cases. The bumpers will not be needed if heat is why you added them. The case does an excellent job dissipating the heat.
It is open with gaps between the metal fins that effectively radiate the heat fast so there is little temperature build up even after hours of listening.
Not sure what material it is made out of, the parts that touch the C9 (the black part) around the edges seems to effectively transfer the heat to the metal fins.
The fins have space for air flow around them.
Whatever is going on here it works and the whole package stays only slightly warm.
I am using tube mode as well class AB which may cause difference for amount of heat compared with class A. Are you using one of the cases?Hmm, I listened for about 1 1/2 hours last night on tube mode and it was quite warm.. hopefully that’s normal. I’ve had lots of tube amps in the past in 2 channel so I know they can run quite hot.
No I’m not using the case. I kinda figure that at that price it should have been included but it was already a stretch for me to buy the C9 and the bump over $2k with the case just psychologically threw me off.. ha ha..I am using tube mode as well class AB which may cause difference for amount of heat compared with class A. Are you using one of the cases?
You need a case, it is worth the extra money.No I’m not using the case. I kinda figure that at that price it should have been included but it was already a stretch for me to buy the C9 and the bump over $2k with the case just psychologically threw me off.. ha ha..
You’re probably right that the Class A is part of the heat thing. I’ll try AB and see.
Hot = sounds better.for me,
class a + tube mode sounds much better than a/b + tube mode
class a + tube mode gets boiling hot,im too scared to wrap my c9 in a case while listening
Will try it again today with case and see, I did that last week and on my recent flights, and I do not think it was any hotter with the case than AB. I agree with you A does sound better, not much though to my ears.for me,
For me, the transients is a tad slower and the bass is rounder, fuller, extending better, but also may be more blooming where the AB is tighter and faster. It should just be personal preferences. However, they don’t sound like night and days differences.Will try it again today with case and see, I did that last week and on my recent flights, and I do not think it was any hotter with the case than AB. I agree with you A does sound better, not much though to my ears.
Can you describe a bit more what you hear that makes it much better in A, particularly is that specific to a frequency range or across the board, is it just in the handling of the transients?
Class A + Tubes should fry an egg after 3-4 hours operation, even without any cases....Hence I have heatsinks on mine lol
Anyways, by 3-4 hours, stock batteries should be almost drained. So you don’t have to worry if you only listen for a short period and charge it up. Unless you go for larger capacity batteries and listen longer
