How does the heat dissipate if it isn’t being conducted from an anodized surface to another metal surface by an efficient thermal conductor like thermal paste ?
I logically think it would be more trapped inside rather than dissipating, and the case is just for looking pretty. Now if you take this and put in your backpack then it is another heat accumulation instance as well
Ofcourse with the powerful heat being generated on my hand in class A and Tube combo, it would try to vent and dissipate itself as much as possible. The proof is that after 2 hours under this mode, the chassis toward the battery tray is Also heated up. So when using the case and seeing “a little heat” doesn’t mean this much heat is being vented out, but rather being trapped in and it is just trying to get out.
Anyways, this case will work if you peel away the aluminum fins, put the case over and then thermal paste heat sinks in replacements to the aluminum fins. However, by using thermal paste and heat sinks alone would be a much better alternative for heat dissipation.....except it doesn’t have that nice looking of the case
When can I expect my battery module ? And how much ?
@bluestorm1992
