It's having more control in high volume and less aggressive sounding than line-out to my preference.What do you prefer about this method? Any downsides?
The downsides, line-out seems have blacker background and clarity than phone out.
The C9 is preemptively protecting itself against Whitigir. It’s only a matter of time until he cracks it open and modifies it
Thanks, I'll give it a try.It's having more control in high volume and less aggressive sounding than line-out to my preference.
I have been modding it all along including, heat sinks, new batteries, new interconnects.... just no invasive processes yet.I'm actually shocked he's gone this long without modding it in some way. Is there any gear he owns that he hasn't modded?
I just checked it and it seems to be sold out. The ifi itraveller seems to be an alternative option.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Somebody up there ^ broke a DX300 doing just that. I wouldn't do it myself, I know from experience sometimes warranties look good on paper but actually claiming for damage may be a different matter.So can I just check... is there any issue using a c9 and a dx300 with a 4.4mm balanced line out connection?
I use this combo of C9 and dx300 from time to time and I am fine. There are others as wellSomebody up there ^ broke a DX300 doing just that. I wouldn't do it myself, I know from experience sometimes warranties look good on paper but actually claiming for damage may be a different matter.
Not, as long as you don't set dx300 line out to high gain; better keep it on low gain.So can I just check... is there any issue using a c9 and a dx300 with a 4.4mm balanced line out connection?
Yes, and it sounds best in low gain with max anywaysI assume the same would be true of the Max? Keep it low gain just to be safe.
Sound wise the Touch by a significant margin. For me 2 out of 10 songs I hear the benefit of the touch on macro and micro detail. Busy music benefits. Both have the house sound. I am not sure about this, do not believe the C9 is going to correct that. The P6K wins for convenience and I like the design better it is cleaner smaller lighter not as gaudy. Comes down to your library, demo all three if you can.So.. Right now, I'm between 2 choices; either go with:
1) Lotoo PAW 6000 + Cayin C9
or
2) Lotoo PAW Gold Touch alone and be done with it!
My only concern is sound quality alone. You can tell I like Lotoo stuff and would like to have their "house sound".
Can someone help?
Based on my general experience, DAP+C9 will usually surpass ANY standalone DAP in SQ. For me, I even slightly prefer N6i + C9 over LP P6 Pro.So.. Right now, I'm between 2 choices; either go with:
or
Can someone help?
That said if you do not want to stack on the go. And decide not to add the C9, which would you prefer. Agree not night and day, the P6K sounds great really, when the music gets real complicated or there is a dramatic building of a wall of sound throughout the tune, all next level daps sound better for that than P6K. I typed wrong above P6P instead of P6K sorry for the confusion, fixed it. That said I chose the L&P because it sounded better to me than the Lotoo touch and the design, but it was real close. I kept my P6K and use it often.Based on my general experience, DAP+C9 will usually surpass ANY standalone DAP in SQ. For me, I even slightly prefer N6i + C9 over LP P6 Pro.
I have owned and sold LP6K and LPGT. I think the difference between them in SQ is noticeable but not day and night. Adding a C9 is day and night.
