3rddimension
- Sep 16, 2012
In order to drive my Alpha Primes efficiently the volume pot floats between 12 - 2 o'clock at 3x gain. I am not experiencing any channel imbalance on mine.
So what is the LC not doing so well?
That was my experience for the first 2 weeks. Now I have the volume below 12:00 at 3x gain, and about 3:00 in 1x gain.
Burn in? Acclimating to it? Not sure....
Maybe my Hugo gives really a really hot signal, but at 3X with my Primes I'm at about 9:00.
It's got great macrodynamics/fun/engagement, but I can see how there is a lot of room for improvement in terms of clarity/coherence/refinement.
Just a guess because I haven't heard the rest of the Cavalli lineup, but I can imagine that throwing a few more thousand dollars at the problem would go really far.
Thanks for the explanation. Perhaps you can let the amp run for a few more days. Things may improve
It's weird though. I tried the same test on here http://www.soundliaison.com/studio-masters/208-carmen-gomes-inc-little-blue and had no bleed through on 3x gain. The first test was done on Window Media Player with one of my CD's.
I would recomend you to use Foobar2000 instead of Windows Media Player.
Cheers
Received my Carbon today. I asked for a delay myself because of work abroad. I also ordered a Stoner Acoustics EGD DAC. Arrived at the same moment by accident. Seemed like a good match based in the specs. Also full balanced. In fact; the EGD only has xlr-outputs which might be a problem for some people. But not with a Carbon! Also roughly the same size, weight and look. Transportable, USB powered (only input), 16/24/32bit or DSD capable, ESS Sabre9018 based etc.
Did not want to wait for the burn-in so listening (actually ENJOYING) both of them right now with my Ether headphones! Sounds like a really like a good match. First impressions: nothing exeggarated of held beck. Really good, neutral but definitely not dull, pleasant, very very very well controlled, detailled sound! Already hearing details I never heard before. Again; not listening but enjoying!
More then enough power for the Ether by the way. Listening quite loud and the volume knob is only at 9.00 (gain at 1x setting).
Scanspeakman
For headphones like the HD650 that aren't (relatively) hard to drive, should using 1x gain with higher volume vs. 3x gain with lower volume make a difference? I haven't experimented much, but seem to slightly prefer 3x gain with low volume seems as it seems to provide more punch, but could all be in my mind.
