Rick,
What are you talking about?
KG on the Orpheus (
http://headwize.com/projects/showfil...more_prj.htm): "A wonderful system, although the inboard D/A converter is awful. Otherwise excellent."
Mike Walker (
http://headwize.com/ubb/showpage.php...53&srch=hev90;) : I've heard them only at a friend's house. They're simply amazing...with all the clarity that electrostats are known for, but with a superbly warm "full" bass (some elctrostats seem kind of tilted toward the highs. Not these). The amp, of course, is a thing of beauty.
Cmoy (
http://headwize.com/ubb/showpage.php...s;amplifier
: Although the Orpheus has gotten consistently good reviews, the HE60/HEV70 has gotten a mixed reception.
And me (
http://www6.head-fi.org/forums/showthread.php?t=82972): "The HEV90 is better than I'd remembered it from my auditioning at WoH Tour, Winlock, and Magnolia Hi-Fi. "Tubes done right" if you will. Almost the detail of the KGSS, a nice warm tubey touch, and enough bass to get the HE90s rockin'. [...] That said, overall the HEV90 won out. The KGSS definitely has more detail and midrange clarity; on pieces like Strauss' Banditen Galop the texture of the gunshots (yep, Wayne, you were right, they're definitely gunshots - the initial pressure followed by the decay is almost exactly the same as a cap-gun I have.) is much more audible. At the same time, however, the increased bass response (the KGSS seems to totally lack bass at the moment. I suspect the HE90s still need charging) and smooth, warm texture of the HEV90 really works well with the HE90s. Art Pepper Meets the Rhythm Section just sounds more real with the HEV90. Like most all-tube designs that I've heard, the HEV90 rounds off the edginess in the music, but does it just enough to make everything sound good. It really is an excellent example of Tubes Done Right. Compared to the Blue Hawaiis that I've heard, the HEV90 has even more, if slightly sloppier, bass and is a true Tube Amp in sound."
And so on and so forth. The
only negative comments about the Orpheus amplifier relate either to the DAC stage (a fairly common complaint) or the circuit design (KG doesn't like tetro-err, pentodes). And KG's comments were based on the schematic -- once he heard it, things changed a little.
