planx
Might be Ironman, or some fat kid.
- Jan 25, 2009
No, I mean to say that replacing headlights from "normal" to "new aftermarket with PROJECTORS" is pretty rice-tastic, like the typical Honda Civics with no-name Headlight conversions. Hmm... Maybe 7000k might be a bit overkill, but with that said, here HIDs without projector seems perfectly legal. Heck, they even offered HIDs on the Acura CSX as an option and that doesn't have projector headlights.
I'm not sure if you are being serious (especially on that bolded part since putting in the HIDs would be "aftermarket-philia crap") but if you run 7000K HIDs with no projectors that's boarding on what I would consider rice-tastic. You are gonna be blinding anyone in front of you with a wall of purplish glare that is not focused in anyway. And in the US (west coast at least) running that system would not necessarily get you pulled over but if you do get pulled over for another violation they will tack on a Fix-It ticket as well (you can have HIDs but they MUST be adaptable/adjustable and have a projector.
