I done it before but I can't recall how
I switch to Linux long ago and that kind of software is not needed, you can do it with any card on the some software.
well sort of, but no, I'm talking about the thing you see in games, you know "plays best on Intel i7"
they're not different in every way at all. etch gen of i7/5/3 use the same core build
Bloomfield and sandy bridge are both core builds.. any sandy bridge cpu is about the same, the only difference is core count cache amount, clock speeds and multiplier/fsb, all of witch only determine the speed and calculations per second of the cpu. not how data is processed.
if a game is built for a sandy bridge i7, it's built for a sandy bridge i5 and i3, of curse a i7 will do better, its has more cores, chase and a higher FSB.
the cpu makes no difference as long as it's fast enough to play the game and has all the extensions needed like mmx, sse and so on.
now some game can't use more then 2/4 cores so in some cases a i7 is to much. the same goes with ram, most games are 32bit , so having more then 6/8 gb of ram in a gaming system is of little use.
edit
I think we "I" gone of topic abit lol
that sounds like what I was told AFAiR
older pcie sound card are supposed to have trouble cuz of the bridge chip , I never had one so I don't know. I was also told the increase numbers of lanes help some how.
but TBH I can't seem to see any difference in the socket as long as you don't need that bridge chip.
pci and pcie should not make any difference when it come to the sound output. but maybe pci could have some noise or emi cuz it's a bus IDK .
