sohho
- Jul 28, 2010
Yes, and actually its an outstanding sound card.
If you use it with a good sound program as JRiver or any other that can handle ASIO output (2i2 has native ASIO drivers) and set it to resample the output to 96000 the result is top notch sound.
Maby, just maybe, you may need to add some EQ (some -3db @ 1kHz) but that depends on your room and system interaction.
