blotmouse
Missed the question earlier.Have you tried regular Sedna tips? They're quite wide (I have wide ears too so am very limited in the tips I can use). OG Sednas have been my go-to for a while.
Also @blotmouse do you have the MEST MKii? (What other IEMs do you have on hand?). I only ask as I had the MEST MKii for a bit and I had the inverse problem that you're having with the Dorado-- namely I found it great some of the time then other times I found it a little shouty up top and lacking presence and weight down low. YMMV etc.
Yeah, I have the MEST MKii. Currently rotate Solaris OG, MEST Mkii, and Dorado 2020.
I received the MEST and Dorado at the same time 6 days ago and prefer the MEST. (MEST fit is great) but really both are a bit rough around the edges. I still prefer the Solaris overall for the rock and metal which is a predominant constant.
I find the MKii has more bass than the OG Solaris, but its a strange one and in strange quantities. Some songs it feels lacking and some it's almost overpowering. Not a huge fan of its treble for rock (that may change). It may be the shouty nature you speak of?
It's almost too opened up, but focus is on the wrong frequency to my ears and they, yeah, dialed out detail to tame it, perhaps?
It is great so far for hip hop and electronica and pop, though. Which is fine, it can be a nice upgrade to my shelved Polaris v2.
I checked those Sedna's and they don't go higher than 14mm, are the regulars sizes and shape dif than the Xelastec L? They're 14mm and are too small for over ear, I can can get a good seal with those w/ earbud style like Atlas.
