Edit:: can't seem to fix the duplication of the images
Yeah, was disappointing to have that happen but at least they took care of it. Seems to be a problem with the adhesive. Must've been some way to create an interlocking method where they "click" together on top of the adhesive... or some micro screws or something. Anything else.I wish they'd sealed it tighter, seems they clued it.
Sigh*,
So less than 24hours with my Vega this happend.
I was trying to insert the foam tips. Is this covered under warranty?
Thanks for another vote! I'll look into a Triton8, once I upgrade to the Sony ZX300. I'll be wanting a balanced cable for that. Also heard good things about PW Audio No5.Another vote for the Triton8 with the Vega
-Collin-
Well, isn't this interesting. I just emailed them this past weekend, because the black nozzle came loose. It has had no impact on SQ, but is happening on both sides. Got a speedy reply and sending them back for warranty.
I'm sorry this happened to you right out of the box. I know how much you're looking forward to getting to experience the sound, and now it's delayed.
-Collin-
-Collin-
It's happened to me twice, the two members who posted about it today, and at least two others I've previously read about. Unless I bought a fake pair from Ken himself at CanJam, then it's a unfortunate issue that I hope they fix, as otherwise the Vega is outstanding in other regards.It might be a fake Vega. I'm sure Campfire probably doesn't use such cheapo glue to hold ear tip housing. I figured they would've used brazing instead of that cheapo glue.
Nope. Not at all. Mine were purchased directly from CA, as in I took a little road trip to Portland, tried the product line, and left with Vega in hand.It might be a fake Vega. I'm sure Campfire probably doesn't use such cheapo glue to hold ear tip housing. I figured they would've used brazing instead of that cheapo glue.
This is what I like about CA. Intuitively, I have no concerns or worries over this issue. I'm so pleased with them, their products, and their service.then it's a unfortunate issue that I hope they fix..
But after a year will they fix that issue for free?? That worries me. I have LyraII and worry about that now. A lot now!This is what I like about CA. Intuitively, I have no concerns or worries over this issue. I'm so pleased with them, their products, and their service.
Haven't heard about it happening to the Lyra or Dorado, though their shell materials are the same.But after a year will they fix that issue for free?? That worries me. I have LyraII and worry about that now. A lot now!
