Tumyum
- Nov 30, 2016
For example, if you vary the volume knob of the DAP, and the sound that comes out of Mojo also varies, then the setup is definitely wrong. It is a proof that the DAP has altered the bits from the original ( in an inferior if not detestable way ), and defeat the purpose of shelling out big bucks on a TOTL gear. The digital volume control on Mojo uses a very powerful processor and top notch algorithm, and is the preferred and correct way to play music.
I use foobar2000 on PC with DSD plugin (https://sourceforge.net/projects/sacddecoder/), and set output device to DSD:WASAPI(push). Then the output is bit-perfect.
I don't understand why some people love to overkill with everything, especially when it comes to music or this forum. They got a perfectly fine DAP but still put a Mojo on it. Stack on top of stack and we got lots of Mr. Stackhouse here. My next question will be: what's the purpose of the DAP or the Mojo in the first place? They swears through their legions that it sound good/bad with or without the Mojo. They also say the same thing between 320kbps and 1411kbps. I read an interest thread here somewhere a few days ago about this topic when people said they could definitely tell the differences between 320 and 1411, while most of them didn't do the blind test.
The more I read into these things regarding to music quality such as stacking gears and formats , it leans me toward to think that things just happened in people's head instead of their ears, unless someone was gifted with excellent hearing or seasonal audiohead, which are plentiful at this forum.
