Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
Jan 25, 2017 at 11:46 AM Post #3,527 of 9,829
  How do you effectively protect the outer housing to prevent chipping and wear? Assuming you are carrying them outside in a case or something.
I'm not so sure you can. Case or not, storing IEMs tends to put the shells together in close proximity and the material wear between the shells is what is results. However you do it, the shells will clink together so I think the chipping and wear is just destined to happen.
Jan 25, 2017 at 12:01 PM Post #3,528 of 9,829
hi guys
If you looking for super cable it is not nothing SILVERGRADE.The sound is very very smooth along with details ,sound stage 3D,smooth vocal, texture bass ,trible Better defined and much better resolution ,sepertion.speed and dynamic. I really am in love
I probably missed it somewhere what cable (the thick cable) manufacturer?
Jan 25, 2017 at 1:19 PM Post #3,531 of 9,829
I carry my IEM's separate from my cables. I stick my Andro's in the furthest corners away from each other in the case. They don't come in contact with each other at all. I guess if I wanted to further decrease the likelihood of them knocking together...I could simply place a rolled up tissue between them.
Jan 25, 2017 at 1:42 PM Post #3,532 of 9,829
I commend you for your dedication to it. I don't put anywhere near as much effort into putting away my IEMs.
Jan 25, 2017 at 4:46 PM Post #3,533 of 9,829
But fle
hi guys
But flexible and very comfortable the sound is great .4 wire 21 awg
Jan 25, 2017 at 11:38 PM Post #3,534 of 9,829
Thanks. I assume removing the housing from the wire will also slow down the wear of those mmcx connectors. I wish I had a pair of protectors for each housing.
Jan 26, 2017 at 1:19 AM Post #3,535 of 9,829
But fle
hi guys
That is not one but two dope cables... Look Fab...
Jan 26, 2017 at 1:22 AM Post #3,536 of 9,829
Why don't you get this case? I use this case and it protects my Andro perfectly from scratch or dent.
https://www.inearz.com/personalized-case/
Jan 26, 2017 at 2:40 AM Post #3,538 of 9,829
