Finally got the Nova in my hand. Looks great with Rx. If only there is ALO DAC, I'll have a complete ALO setup.
Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
- Thread starter KB
Midgetguy
What if you took a sharpie and some duct tape and wrote "ALO" on the ODAC? Does that count?
Haha... nice advice
kino lau
- Sep 18, 2014
Haha... nice advice
I'm going to write HUGO TT on my X5/E12A stack
Hehe... that will be the cheapest way to improve percepted sound quality.
kino lau
- Sep 18, 2014
Swapped the SpinFit's that I was using for some Penon Audio tips. http://penonaudio.com/3-Pairs-In-ear-Silicone-Eartips They seal better than the SpinFit and now the bass is much more defined with the Andromeda.
moedawg140
Grand Master Moe "G"….Don't crossface me, bro!
Ping Pong Champ: SF Meet (2016,2017), CanJams (London 2016, RMAF 2016, NYC 2017, SoCal 2017, RMAF 2017)
The Penon Audio tips are great! I'm going to go with something else that may or may not prove to be the best for my wants.
Let's see if @twister6 can guess this one (since that's something he loves to do).
- Jan 10, 2016
arent those penons same as those Aliexpress red core tips?The Penon Audio tips are great! I'm going to go with something else that may or may not prove to be the best for my wants.
can guess this one (since that's something he loves to do). :tongue_smile:
moedawg140
I am not 100 percent certain as I have never purchased anything from Aliexpress, but I am most sure someone can/will clarify for you.
I can recommend Ortofon eartips. There is almost no impact to the sound compared to default eartips, while being more comfortable and seal very well.
alvinmate
- Aug 22, 2012
Hi Folks,
Anyone here using the Isolation range of Comply's that has wax guard?
I'm just wondering does the wax guard impact the SQ in any way and also what's the best model from Isolation that fits the Andros.
Thanks
Thanks
Gilles De Rais
- Aug 4, 2008
Hi fellow Antipodean,
400 series is what you're looking for. My recollection is that the wax guard model is in fact what Campfire Audio recommend - certainly for the Lyras in my ears at the moment. Minisdisc shoulsd have them in stock.
regards,
Giles
regards,
Giles
hpnutz
- Jun 9, 2016
+1 on 400 series- transparent sound and good isolation
goldendarko
- Nov 9, 2013
I am and they work and sound the same as regular complys to me. Only notice a difference with silicon tips to be honest.Hi Folks,
Thanks
alvinmate
- Aug 22, 2012
Thanks guys.... will buy them from Minidisc
BTW is 400 series any easier to put them on the thick bore of the Andros as I struggled a bit with the stock ones.
Total: 10 (members: 0, guests: 10)
