wink
His amps are made out of recycled beer cans
and his source from tomatos.
- Apr 13, 2009
My Barista is a microprocessor.
Same. If only it was a little more consistent. I've had cups that were absolutely spectacular and some that were not great.
But then again, not the greatest coffee maker in the world. Maybe I should start working on my coffee setup now that my headphone setup is done for now. Hi-fi coffee coffee filters, silver power cables, where should I start?![]()
Go B.A.L.A.N.C.E.D. end-to-end.
Do you think I should go for solid state or tubes? Open or closed cups? So many options!![]()
I was actually thinking about it, and maybe I should look to up my coffee game. My biggest problem is that I am in a dorm so I would need something all-in-one that Doesn't take up much desk space, so the keurig seemed like a logical choice. But lately I've been wondering if there was something that was similar in function but better in terms of quality. Something to look up I suppose.
Though I don't personally own one, I'm positive that you can get a machine that fits your needs and makes a hella good cup of joe. I have a buddy of mine that basically bought what Starbucks uses to make there espresso but for personal use. Said it cost him around $1,200 but damn does it taste goodA little research could definitely lead you to what you are looking for. Good luck with your search.
@PL4Y3R 0N3
French press dude! Pre ground coffee is right around the perfect consistency and all you need is some hot water. *plot twist* use the Keurig as a kettle
WHY DIDN'T I THINK OF THAT!!!
I can't believe I never considered that. I'll have to start looking for a really small French press now, and then I'll use the keurig as a kettle on days where I have to lime to actually make coffee. Genius!
