Br777
- Feb 2, 2010
Hi all
i would like to know how ya'll feel about the following questions. please explain your answers if necessary
relate these questions to someone who is only going to be making cables and LOD's
thanks a lot.
Solder:
-rosin core Y/N?
-lead or no lead?
-with flux or without?
-any benefits to certain "gauge/thickness" of solder over others?
soldering
-ideal soldering temperature
-ideal solder iron wattage?
-variable temp necessary? if so why?
shring tubing
-what to you use to shrink your heat shrink tubing
-some people put heat shrink on the outside of their connectors, usually overlapping onto the wire ends... a good example is ALO twag cables
what is the purpose of this? asthetic or something else?
-do you ever put heat shrink over the inner area of a mini jack covering all the solder joints as way of added strain releif?
thanks again.
thanks a lot.
Solder:
-rosin core Y/N?
-lead or no lead?
soldering
shring tubing
thanks again.
