why do you think certain posters drive you to such emotional contempt? If you thumb through a psychology 101 text at the library there are some possible explanations that may or may not apply.....I'm suggesting science is not always the greatest thing or ultimate reference because it can be corrupted over time by certain cultural movements. And that in such a zeitgeist it may be possible for such a group to overlook the possibility that they are not in the golden era they think they are in and that the past may have had higher points in some or all aspects. This relates to burn in because you fellas, as a group are totally set against it and claim science would have found a explanation for if if real. I'm suggesting science can't find much solution or explanaton for many other things and so logically this opens up th epossibility that even though current science cannot account for something does not mean a phenomenon doesn't exist, and then I would extend the possibility further, to incorporate the prior point, and suggest that past civilizations may have been able to. i.e.. alchemy etc... thanks for the back n forth. this is gentlemenly and while I suspect you feel it's a waste of time, I thank you for indulging me and not hurling insults..
Science may not be able to explain cable burn in (just as it may not be able to explain many unprovable, undisprovable "theories" with no basis in reality) but common sense can explain why it is important to perform a well-blinded test between your two cables (one burned in and one not, as the case may be) before raving about the improvements:
Consider an unblinded test. There's cable A and cable B, which let's say are known to be objectively sonically identical to all listeners, with the same build, except, say, A is colored blue and B is red. You may even know that this is so going into the test. Such is an ideal case for an unblinded test for someone to correctly conclude that two items are identical. Now let's see what happens:
1. You listen to A playing some music and try to note down its sound.
2. You listen to B playing some more music and try to note down its sound. Now, you may find the sound to be identical (as predicted) OR, something may sway your listening impression to be a little different from A. Perhaps it would be because you're listening to a different snippet of the same piece of music. Perhaps you're listening to the same snippet, but paying attention to a different part of that same snippet. Perhaps your headphones shifted a little when you went about plugging and unplugging cables, coloring the sound differently. Perhaps the room is getting warmer or cooler, affecting your temperament. Any of a thousand things not sound-related could sway your perception of the sound in a random direction.
3. You could even go through several A/B switches not "noticing" any difference, but eventually you "notice" a difference. Say, you thought you heard that B is warmer than A. Now what happens when you switches from B back to A? If you had no expectation bias going into the test, you do now--you heard it yourself, B is warmer than A!
If this were a blinded ABX test, that spurious impression of B being warmer than A is lost in the next round as the identity of B itself is gone--unless B really were warmer than A in a subjectively detectable way for you, in which case you'd start hitting on the right answer for X more and more. For a sighted test, though, the "warmer" classification, rightly or wrongly, sticks with B. Now, you may run into further trials with conflicting impressions, but expectation bias (which I'm sure you've heard explained to you plenty of times here) dictates that you disregard these conflicting impressions more and more as your impression becomes a conviction, until your sense of hearing itself becomes clouded by your expectation and you simply hear what you expect to hear every time.
So, B "is" warmer than A.
4. In the same manner, you attribute further characteristics in audio jargon randomly to each cable. Upon extended "testing", said attributions become just as firm as they are random.
5. In the end, you are able to expound on the virtues of cable B over cable A (and / or vice versa) in 10 pages of detailed sonic impressions, covering such disparate areas as pace, rhythm, timing, attack, decay, soundstage, distortion, ... in a manner that could earn high accolades in an audio magazine.
Thus, as you can see, even in the most ideal of circumstances, one almost never "finds" two truly identical items to be identical in a sighted "test".
Now, you may argue that just as sighted tests fail to identify identical items as identical, ABX tests fail to identify subtly different items as different. That may even be true. But even in that case, you have to admit that a sighted impression that two items are different is not proof of anything--because a sighted test never finds two things to be identical.
