StanD
- Oct 2, 2013
This thread quickly turned to useless junk by those seeking entertainment.
get back to me when you and you're science discovers a cure for anything, even the common cold still exists. . Until I see some results from your camp, I'll stick with magic which so far has a better cure rate and overall remedy and explanation for life's ill's.
And so just because today, no one can document or explain other properties of a cable that may account for burn in does not negate the possibility.
right, that was the last one. many years ago. Trillions of dollars in research and walks for the cure and nothing....they can't even get a cure, let alone root out the cause of anything. There's plenty of info to suggest a placebo sugar pill does better than modern pharmacutics. The point is progress is not as linear or as one directional as some think, and the latest and greatest scientific knowledge does not necessarily represent something of value. Think of the great pyramids. The older ones are far superior and the ones after are shrunken malformed, technically and aesthetically inferior. You'd think they would have gotten better at building them over time rather than worse. Where was the latest and greatest towards the end of that era? ob\viously tech and civilization goes up and down like a sine wav not like a straight line upwards and some way say many aspects of modern culture are on the wane. And so just because today, no one can document or explain other properties of a cable that may account for burn in does not negate the possibility.
why do you think certain posters drive you to such emotional contempt? If you thumb through a psychology 101 text at the library there are some possible explanations that may or may not apply.....I'm suggesting science is not always the greatest thing or ultimate reference because it can be corrupted over time by certain cultural movements. And that in such a zeitgeist it may be possible for such a group to overlook the possibility that they are not in the golden era they think they are in and that the past may have had higher points in some or all aspects. This relates to burn in because you fellas, as a group are totally set against it and claim science would have found a explanation for if if real. I'm suggesting science can't find much solution or explanaton for many other things and so logically this opens up th epossibility that even though current science cannot account for something does not mean a phenomenon doesn't exist, and then I would extend the possibility further, to incorporate the prior point, and suggest that past civilizations may have been able to. i.e.. alchemy etc... thanks for the back n forth. this is gentlemenly and while I suspect you feel it's a waste of time, I thank you for indulging me and not hurling insults..
