yklee118
- May 19, 2007
I have a rather troublesome issue with the C&C Box+. The batteries are dead after just using them for about less than 300-hours (two-years old). Less than six charging cycles. Here is the thing, I thought I was able to treat this amp as a desktop unit since the batteries were beyond saving. That is not the case. Low charge or dead batteries equal very distorted sound. It would seem the batteries provide some extra reserve or sorts.
Now my question is where can I find a battery (two 3.7V lithium-polymers are used with 750mAh) that matches the dimensions and capacity. I have searched just about everywhere with absolutely no success. The Dimensions are 48mm by 30mm by 4mm thick each cell. I would sincerely appreciate the help since this particular model of the C&C Box is fitted with the AD823 OP amp instead of the AD822. Very good sounding amplifier with both the AKG K701 and Sennheiser HD650.
Everybody have a great week.
Thanks
Thanks
