whatsntomake
- Sep 16, 2011
I'm having some audio/technical problems with my BursonAudio 160D. I'm wondering if anybody could share some troubleshooting advice.
My burson is hooked via usb to my computer.
Whenever I play audio, music blasts out disproportionately loud on only one side. I have this problem on 2 headphones and a speaker (connected via the preout). I've verified that both the headphones and speaker work normally when not plugged into the burson.
It's quite loud that it can be reasonably heard from another room despite the volume (both the physical knob and software volume adjuster) being set quite low.
I bought some deoxit and cleaned the contacts but this problem still persists.
To be sure that this isn't a problem with my computer (at least on the software side) - I've plugged my headphones and speaker directly into my computer and the audio plays normally.
Thanks for any help you can give!
