Burson V7 Classic Pro and V7 Vivid Pro - Hi-Fi audiophile solid-state op-amps
Jan 17, 2025 at 5:03 PM Post #331 of 385
Just upgraded my Burson C3R from the V6Vs to the V7C. Really happy with the sound. I use a pair of OG Focal clears and found the original sound a bit thin and with a tad too much treble and a little metallic. The classics are more smooth, warm and richer. I do miss a little of the airyness and dynamics of the vivids but over all am much happier with the classics. Definitley worth the upgrade.
Jan 18, 2025 at 3:01 AM Post #332 of 385
I have to hear the v7 classics yet, but having listened to the v7 vivids, and how big of a upgrade that was compared to the v6 vivids, I can only imagine they sound amazing.
I have heared the smooth soundings v6 classics, how do they compare?
Jan 22, 2025 at 11:24 AM Post #334 of 385
Or get 2 SIL (Sonic Imagery Labs)992 (Singles) and 2 Sparkos SS2590 (Duals).
See:
https://www.head-fi.org/threads/new...d-amp-preamp-changeable-opamps.912911/page-46
Does someone have a nice explanation how to order sparkos in this configuration?
I have 2x V7 Vivid Dual and 2x V7 Classic Single in my Playmate 2 + Arya Stealth for a couple of months. But I found myself enjoying the music less. I tried to change them with stock ones, and found that this particular combo makes music less energetic and decrease the sound stage, despite adding a ton of resolution.
Now I'm thinking to get 2x V7 Vivid Single and 2x V7 Classic Dual to try all combination, but I don't think it worth it... Maybe better this combo?
Jan 22, 2025 at 11:52 AM Post #335 of 385
For the PM2 I really enjoy 2x SI994 duals, and 2x Sparkos SS2590 singles. Here's that setup:
https://www.head-fi.org/threads/bur...amp-dsd512-usb-c-toslink.947342/post-17338678
Two posts above that link a brave soul was able to get 4 Sparkos SS2590's into the PM2 which I bet sounds even better. I didn't dare try that though as that puts the op amps too close to touching the case for my comfort. If it was me I'd look at potentially putting in the 2 SS2590 singles along with your V7 Vivids. If the sound still isn't to your liking then the SI994's would be good to try instead of the V7's.
Jan 22, 2025 at 11:59 AM Post #337 of 385
The way I did it.
Jan 22, 2025 at 11:59 AM Post #338 of 385
Is a single channel makes a lot of difference compared to dual? The Sparkos dual are 150 EUR each (plus expansion cables), which is quite expensive for an experiment. Maybe just get a Conductor GT4? :beyersmile:
Jan 22, 2025 at 12:19 PM Post #340 of 385
So for the Sparkos dual I need to get this one, plus Burson expansion cables, right?
Yes, 2 fully assembled adapter with two SS2590’s already soldered into it" or if you prefer to solder them yourself, you can have them a bit cheaper. And yes extensions from Burson. Not cheap, but it's a treat IMO.
Jan 22, 2025 at 12:22 PM Post #341 of 385
Do we have anywhere a comparison between Playmate 2 and something like GT3/GT4? I'm thinking maybe just put money aside and get GT4 on some discounts. Looks like balance output can bring more energy. But definitely not a topic of this thread. Thanks!
Jan 22, 2025 at 12:29 PM Post #342 of 385
Have no info about that comparison.
Getting GT4 seems a good option.
Jan 22, 2025 at 1:45 PM Post #343 of 385
I know what you are experiencing, i reccomend polish op-amps from Muzg audio. very even sounding the whole frequency response
Jan 22, 2025 at 3:54 PM Post #344 of 385
not too OTL?
