Driving a headphone well is not just reaching a certain volume level. There is much more to it, like bass presence and definition, instrument separation, imaging, refinement, 3D space...
These caracteristics are totally fullfilled by the D8000pro IMO ! This is, maybe, why these cans are not very "amp sensitive" ?
My ath-ad2000x are very sensitive headphones and easy to drive but even I heard difference in using the soloist 3x compared to the built in amplifier of my neo idsd.
I'm glad for you...
Maybe my old ears can't achieve this
I'm now, listening the Lejonklou for theh 2 next days and then will switch to the Soloist. I'll report if I can ear any difference...
Make sure you test with a pair of competent speakers and a good power amp as well. The Soloist workes great with active monitors, the difference is drastic when compared with RME ADI-2 alone.
The first thing I noticed on the Soloist when I first compared them to other solid state is its air and its ability to make the sound more analog. Most solid state amplifiers have "edgy" sound. Maybe non treble sensitive people will not be bothered by this.
I just thought I need to emphasise that I mostly evaluated the Soloist 3XP in 'headphone power amp mode'. Completely bypassing the amp's volume circuit to my ears leads to a much more dynamic and clear sound with better impact, separation and sense of space.
In normal mode it is still a great amp but IMHO the true magic hides in bypassing the whole volume circuit which is not possible on too many amps. Normal mode is somehow less refined/detailed with a lesser sense of soundstage depth and definition. Normal mode has a sweeter analogue tone but I much prefer the increased clarity/resolution and impact of the headphone power amp mode.
I am not an expert, so I am not sure what exactly is going on, just following my ears as always and sharing my findings.
I have the Soloist 3XP since first pre-order batch and did not really realize the existance of the power amp mode .
...trying it for the first time now with the Composer 3XP and Meze Empyrean. What DAC/pre-amp you use with the Soloist 3XP?
Here I am...headphone power amp mode
So yes, it bypasses the internal volume control but engages the DAC volume control.
Please make sure your DAC is in pre-amp mode at a very low volume otherwise your ears will bleed)
BTW, with DAC volume control you don't have that volume jump at 52.
Please make sure you DAC is in pre-amp mode otherwise your ears will bleed)
Exactly. One must be very careful. It is easy to blow one or two drivers if careful measures have not been taken regarding volume levels.
From eardrum burst to brain fry everything is on the cards. Be smart folks.
Please make sure you DAC is in pre-amp mode otherwise you can your eyes will bleed)
To be fair I did the same a couple of times with my Arya and they survived. (Kudos to Arya transducer quality.)
Since then I am extra careful with my Empyrean and I unplug the headphones more often than I used to be.
I also have the RME w/ my Burson. Just to clarify for me, if you do this headphone power amp mode, are you still using the Burson circuitry? All you're doing is controlling volume via the RME?
Absolutely, the RME acts like volume control only since the headphones are plugged in the Soloist Unfortunately this mode does not work on the analog outputs of the Soloist, only on the headphone outputs. To switch to XLR/RCA you need to exit the headphone amp mode.
